Size: 4 x 6
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 38.7 lbs
Dist. Selfweight: 4.99 plf
Total Weight: 39.9 lbs
Beam Design 2021A222
4/4/2021 1
4/4/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (93.00 + 3)] x (12 in./ft.)3 = 1.07 ft3
Volumespan = N[A x L] = 1 x [19.25 x 93.00] x (12 in./ft.)3 = 1.04 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.07 = 39.9 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.04 = 38.7 lbs
Distributed Self Weight (ws) = = 4.99 plf
100 lbs
75 lbs
ws = 4.99 plf
7.75 ft.
7.50 ft.
107.46 lbs
107.46 lbs
4/4/2021 3
fb = = 256.1 psi
 fb = 256.1 psi < Fbx' = 1000.0 psi  (CSI = 0.26)   ➜  OK
4/4/2021 4
fv* = = 8.15 psi
 fv* = 8.15 psi < Fvx' = 175.00 psi  (CSI = 0.05)   ➜  OK
fv = = 8.32 psi
 fv = 8.32 psi < Fvx' = 175.00 psi  (CSI = 0.05)   ➜  OK
4/4/2021 5
ΔLL =   =   = 0.02 in.
(L/d)LL = 93.00 / 0.02 = 3770
 ΔLL = 0.02 in = L/3770 < L/360   ➜  OK
ΔTL =   =   = 0.05 in.
(L/d)TL = 93.00 / 0.05 = 1893
 ΔTL = 0.05 in = L/1893 < L/240   ➜  OK
fc⊥ = = 10.2 psi
 fc⊥ = 10.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.02)   ➜  OK
4/4/2021 6
