Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 60 plf
Dead Load: 20 plf
Selfweight: 81.4 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 82.7 lbs
Beam Design 2021A22
1/8/2021 1
Beam Design 2021A22
1/8/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (189.00 + 3)] x (12 in./ft.)3 = 2.42 ft3
Volumespan = N[A x L] = 2 x [10.88 x 189.00] x (12 in./ft.)3 = 2.38 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.42 = 82.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.38 = 81.4 lbs
60 plf
20 plf
ws = 5.17 plf
15.75 ft.
15.50 ft.
681.33 lbs
681.33 lbs
Beam Design 2021A22
1/8/2021 3
fb = = 1205.8 psi
 fb = 1205.8 psi < Fbx' = 1242.0 psi  (CSI = 0.97)   ➜  OK
Beam Design 2021A22
1/8/2021 4
fv* = = 42.71 psi
 fv* = 42.71 psi < Fvx' = 207.00 psi  (CSI = 0.21)   ➜  OK
fv = = 46.25 psi
 fv = 46.25 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
Beam Design 2021A22
1/8/2021 5
ΔLL = = 0.54 in.
(L/d)LL = 189.00 / 0.54 = 347
 ΔLL = 0.54 in = L/347 > L/360   ➜  NG
ΔTL = = 0.77 in.
(L/d)TL = 189.00 / 0.77 = 244
 ΔTL = 0.77 in = L/244 < L/240   ➜  OK
fc⊥ = = 75.7 psi
 fc⊥ = 75.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.12)   ➜  OK
Beam Design 2021A22
1/8/2021 6
