Grade: SPF No.1
Size: 4 x 10
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 75 plf
Dead Load: 30 plf
Selfweight: 109.6 lbs
Dist. Selfweight: 6.54 plf
Total Weight: 111.2 lbs
CL Beam Stability Factor 0.952 - - - - -
Beam Design 2021A219
4/1/2021 1
SPF No.1 875 450 135 425 1150 1400000 510000 0.42
4/1/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (201.00 + 3)] x (12 in./ft.)3 = 3.82 ft3
Volumespan = N[A x L] = 1 x [32.38 x 201.00] x (12 in./ft.)3 = 3.77 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.82 = 111.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.77 = 109.6 lbs
Distributed Self Weight (ws) = = 6.54 plf
30 plf
ws = 6.54 plf
16.75 ft.
16.50 ft.
17.00 ft.
948.11 lbs
948.11 lbs
4/1/2021 3
lu = Unbraced Length = 16.750 ft.
lu/d = = 21.73
le = 1.63lu + 3d = 1.63(201.0) + 3(9.25) = 355.38 in. = 29.61 ft.  (NDS Table 3.3.3)
Rb = = 16.38
 Rb = 16.38 < 50   ➜  OK
4/1/2021 4
FbE = = 2280.62 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.15)(1)(1)(1.2)(1)(1) = 1207.50 psi
CL =   = 0.952
Fbx' = (875)(1.15)(1)(1)(0.952)(1.2)(1)(1) = 1149.1 psi
fb = = 940.5 psi
 fb = 940.5 psi < Fbx' = 1149.1 psi  (CSI = 0.82)   ➜  OK
fv* = = 39.30 psi
 fv* = 39.30 psi < Fvx' = 155.25 psi  (CSI = 0.25)   ➜  OK
fv = = 43.28 psi
 fv = 43.28 psi < Fvx' = 155.25 psi  (CSI = 0.28)   ➜  OK
4/1/2021 5
ΔLL = = 0.41 in.
(L/d)LL = 201.00 / 0.41 = 489
 ΔLL = 0.41 in = L/489 < L/360   ➜  OK
ΔTL = = 0.61 in.
(L/d)TL = 201.00 / 0.61 = 329
 ΔTL = 0.61 in = L/329 < L/240   ➜  OK
fc⊥ = = 90.3 psi
 fc⊥ = 90.3 psi < Fc⊥x' = 425.00 psi  (CSI = 0.21)   ➜  OK
4/1/2021 6
