Size: 3.5 x 9
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 0 lbs
Dead Load: 800 lbs
Selfweight: 123.7 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 125.5 lbs
Beam Design 2021A218
3/31/2021 1
d = 9.000 in.
3/31/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (201.00 + 3)] x (12 in./ft.)3 = 3.72 ft3
Volumespan = N[A x L] = 1 x [31.50 x 201.00] x (12 in./ft.)3 = 3.66 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.72 = 125.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.66 = 123.7 lbs
0 lbs
800 lbs
  ws = 7.39 plf
16.75 ft.
16.50 ft.
17.00 ft.
462.77 lbs
462.77 lbs
3/31/2021 3
Fbx' = (2400)(0.9)(1)(1)(1.0) = 2160.0 psi
fb = = 916.6 psi
 fb = 916.6 psi < Fbx' = 2160.0 psi  (CSI = 0.42)   ➜  OK
3/31/2021 4
Fvx' = (265)(0.9)(1)(1) = 238.50 psi
fv* = = 21.73 psi
 fv* = 21.73 psi < Fvx' = 238.50 psi  (CSI = 0.09)   ➜  OK
fv = = 21.99 psi
 fv = 21.99 psi < Fvx' = 238.50 psi  (CSI = 0.09)   ➜  OK
3/31/2021 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 201.00 / 0.00 = ∞
ΔTL =   =   = 0.39 in.
(L/d)TL = 201.00 / 0.39 = 518
 ΔTL = 0.39 in = L/518 < L/240   ➜  OK
fc⊥ = = 44.1 psi
 fc⊥ = 44.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.07)   ➜  OK
3/31/2021 6
