Size: 2.5 x 6
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 55.4 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 56.3 lbs
Beam Design 2021A216
3/31/2021 1
b = 2.500 in.
d = 6.000 in.
A = 2.500 x 6.000 = 15.00 in.2
Sx = (2.500)(6.000)2/6 = 15.00 in.3
Sy = (2.500)2(6.000)/6 = 6.25 in.3
Ix = (2.500)(6.000)3/12 = 45.00 in.4
Iy = (2.500)3(6.000)/12 = 7.81 in.4
3/31/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [15.00 x (189.00 + 3)] x (12 in./ft.)3 = 1.67 ft3
Volumespan = N[A x L] = 1 x [15.00 x 189.00] x (12 in./ft.)3 = 1.64 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.67 = 56.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.64 = 55.4 lbs
100 lbs
75 lbs
  ws = 3.52 plf
15.75 ft.
15.50 ft.
115.63 lbs
115.63 lbs
3/31/2021 3
fb = = 638.5 psi
 fb = 638.5 psi < Fbx' = 2400.0 psi  (CSI = 0.27)   ➜  OK
3/31/2021 4
fv* = = 11.34 psi
 fv* = 11.34 psi < Fvx' = 265.00 psi  (CSI = 0.04)   ➜  OK
fv = = 11.52 psi
 fv = 11.52 psi < Fvx' = 265.00 psi  (CSI = 0.04)   ➜  OK
3/31/2021 5
ΔLL =   =   = 0.17 in.
(L/d)LL = 189.00 / 0.17 = 1088
 ΔLL = 0.17 in = L/1088 < L/360   ➜  OK
ΔTL =   =   = 0.36 in.
(L/d)TL = 189.00 / 0.36 = 519
 ΔTL = 0.36 in = L/519 < L/240   ➜  OK
fc⊥ = = 15.4 psi
 fc⊥ = 15.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.02)   ➜  OK
3/31/2021 6
