Species: Alaska Yellow Cedar
Grade: AYC SS
Size: 4 x 12
Design Span (L): 13.50 ft.
Clear Span: 13.00 ft.
Total Span: 14.00 ft.
Selfweight: 121.5 lbs
Dist. Selfweight: 9.00 plf
Total Weight: 126.0 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2021A215
3/30/2021 1
AYC SS 1350 800 225 510 1200 1500000 550000 0.46
G = 0.46
3/30/2021 2
= 32.92 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (162.00 + 6)] x (12 in./ft.)3 = 3.83 ft3
Volumespan = N[A x L] = 1 x [39.38 x 162.00] x (12 in./ft.)3 = 3.69 ft3
Total Weight (WT) = ρw x Volumetotal = 32.92 x 3.83 = 126.0 lbs
Self Weight (WS) = ρw x Volumespan = 32.92 x 3.69 = 121.5 lbs
Distributed Self Weight (ws) = = 9.00 plf
ws = 9.00 plf
13.50 ft.
13.00 ft.
1288.02 lbs
1288.02 lbs
3/30/2021 3
lu/d = = 2.13
Rb = = 6.74
 Rb = 6.74 < 50   ➜  OK
3/30/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 550000(0.9)(1)(1) = 495000 psi
FbE = = 13082.52 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1350)(1.00)(0.85)(1)(1.1)(1)(1) = 1262.25 psi
CL =   = 0.995
Fbx' = (1350)(1.00)(0.85)(1)(0.995)(1.1)(1)(1) = 1255.6 psi
fb = = 681.3 psi
 fb = 681.3 psi < Fbx' = 1255.6 psi  (CSI = 0.54)   ➜  OK
Fvx' = (225)(1.00)(0.97)(1)(1) = 218.25 psi
fv* = = 40.74 psi
 fv* = 40.74 psi < Fvx' = 218.25 psi  (CSI = 0.19)   ➜  OK
fv = = 47.32 psi
 fv = 47.32 psi < Fvx' = 218.25 psi  (CSI = 0.22)   ➜  OK
3/30/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1500000(0.9)(1)(1) = 1350000 psi
ΔLL = = 0.13 in.
(L/d)LL = 162.00 / 0.13 = 1215
 ΔLL = 0.13 in = L/1215 < L/360   ➜  OK
ΔTL = = 0.25 in.
(L/d)TL = 162.00 / 0.25 = 660
 ΔTL = 0.25 in = L/660 < L/240   ➜  OK
Fc⊥x' = (510)(0.67)(1)(1) = 341.70 psi
fc⊥ = = 61.3 psi
 fc⊥ = 61.3 psi < Fc⊥x' = 341.70 psi  (CSI = 0.18)   ➜  OK
3/30/2021 6
