Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 83 plf
Dead Load: 165 plf
Selfweight: 167.3 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 170.6 lbs
Beam Design 2021A212
3/29/2021 1
3/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (153.00 + 3)] x (12 in./ft.)3 = 4.57 ft3
Volumespan = N[A x L] = 3 x [16.88 x 153.00] x (12 in./ft.)3 = 4.48 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.57 = 170.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.48 = 167.3 lbs
83 plf
165 plf
ws = 13.12 plf
12.75 ft.
12.50 ft.
13.00 ft.
1697.30 lbs
1697.30 lbs
3/29/2021 3
fb = = 670.8 psi
 fb = 670.8 psi < Fbx' = 862.5 psi  (CSI = 0.78)   ➜  OK
3/29/2021 4
fv* = = 42.07 psi
 fv* = 42.07 psi < Fvx' = 201.25 psi  (CSI = 0.21)   ➜  OK
fv = = 49.32 psi
 fv = 49.32 psi < Fvx' = 201.25 psi  (CSI = 0.25)   ➜  OK
3/29/2021 5
ΔLL = = 0.07 in.
(L/d)LL = 153.00 / 0.07 = 2317
 ΔLL = 0.07 in = L/2317 < L/240   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 153.00 / 0.21 = 737
 ΔTL = 0.21 in = L/737 < L/180   ➜  OK
fc⊥ = = 125.7 psi
 fc⊥ = 125.7 psi < Fc⊥x' = 565.00 psi  (CSI = 0.22)   ➜  OK
3/29/2021 6
