Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 285 plf
Dead Load: 142.5 plf
Selfweight: 78.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 80.2 lbs
CL Beam Stability Factor 0.967 - - - - -
Beam Design 2021A21
1/7/2021 1
Beam Design 2021A21
1/7/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.34 ft3
Volumespan = N[A x L] = 2 x [16.88 x 117.00] x (12 in./ft.)3 = 2.29 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.34 = 80.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.29 = 78.2 lbs
285 plf
142.5 plf
ws = 8.02 plf
9.75 ft.
9.50 ft.
10.00 ft.
2177.58 lbs
2177.58 lbs
Beam Design 2021A21
1/7/2021 3
lu = Unbraced Length = 9.750 ft.
lu/d = = 10.40
le = 1.63lu + 3d = 1.63(117.0) + 3(11.25) = 224.46 in. = 18.70 ft.  (NDS Table 3.3.3)
Rb = = 16.75
 Rb = 16.75 < 50   ➜  OK
Beam Design 2021A21
1/7/2021 4
FbE = = 2480.62 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1)(1)(1) = 1035.00 psi
CL =   = 0.967
Fbx' = (900)(1.15)(1)(1)(0.967)(1)(1)(1) = 1001.1 psi
fb = = 981.4 psi
 fb = 981.4 psi < Fbx' = 1001.1 psi  (CSI = 0.98)   ➜  OK
fv* = = 76.22 psi
 fv* = 76.22 psi < Fvx' = 207.00 psi  (CSI = 0.37)   ➜  OK
fv = = 94.36 psi
 fv = 94.36 psi < Fvx' = 207.00 psi  (CSI = 0.46)   ➜  OK
Beam Design 2021A21
1/7/2021 5
ΔLL = = 0.10 in.
(L/d)LL = 117.00 / 0.10 = 1150
 ΔLL = 0.10 in = L/1150 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 117.00 / 0.16 = 752
 ΔTL = 0.16 in = L/752 < L/240   ➜  OK
fc⊥ = = 242.0 psi
 fc⊥ = 242.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.39)   ➜  OK
Beam Design 2021A21
1/7/2021 6
