Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Live Load: 124 plf
Dead Load: 124 plf
Selfweight: 27.3 lbs
Dist. Selfweight: 2.14 plf
Total Weight: 27.8 lbs
Beam Design 2021A208
3/28/2021 1
3/28/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (153.00 + 3)] x (12 in./ft.)3 = 0.74 ft3
Volumespan = N[A x L] = 1 x [8.25 x 153.00] x (12 in./ft.)3 = 0.73 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.74 = 27.8 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.73 = 27.3 lbs
Distributed Self Weight (ws) = = 2.14 plf
124 plf
124 plf
ws = 2.14 plf
12.75 ft.
12.50 ft.
13.00 ft.
1625.90 lbs
1625.90 lbs
3/28/2021 3
fb = = 8065.4 psi
 fb = 8065.4 psi > Fbx' = 1150.0 psi  (CSI = 7.01)   ➜  NG
3/28/2021 4
fv* = = 269.09 psi
 fv* = 269.09 psi > Fvx' = 201.25 psi  (CSI = 1.34)   ➜  NG
fv = = 289.93 psi
 fv = 289.93 psi > Fvx' = 201.25 psi  (CSI = 1.44)   ➜  NG
3/28/2021 5
ΔLL = = 2.53 in.
(L/d)LL = 153.00 / 2.53 = 60
 ΔLL = 2.53 in = L/60 > L/360   ➜  NG
ΔTL = = 5.11 in.
(L/d)TL = 153.00 / 5.11 = 30
 ΔTL = 5.11 in = L/30 > L/240   ➜  NG
fc⊥ = = 361.3 psi
 fc⊥ = 361.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.64)   ➜  OK
3/28/2021 6
