Beam Design - Garage Door Header
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 45 plf
Dead Load: 15 plf
Selfweight: 65.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 66.1 lbs
Beam Design Carl Douglass 12420 Midway 2110
3/25/2021 1
3/25/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 1.93 ft3
Volumespan = N[A x L] = 1 x [16.88 x 195.00] x (12 in./ft.)3 = 1.90 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.93 = 66.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.90 = 65.1 lbs
45 plf
15 plf
ws = 4.01 plf
16.25 ft.
16.50 ft.
528.07 lbs
528.07 lbs
3/25/2021 3
fb = = 801.3 psi
 fb = 801.3 psi < Fbx' = 1035.0 psi  (CSI = 0.77)   ➜  OK
3/25/2021 4
fv* = = 40.89 psi
 fv* = 40.89 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
fv = = 46.23 psi
 fv = 46.23 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
3/25/2021 5
ΔLL = = 0.25 in.
(L/d)LL = 195.00 / 0.25 = 787
 ΔLL = 0.25 in = L/787 < L/240   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 195.00 / 0.35 = 553
 ΔTL = 0.35 in = L/553 < L/180   ➜  OK
fc⊥ = = 117.3 psi
 fc⊥ = 117.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.19)   ➜  OK
3/25/2021 6
