Beam Design - Kitchen Wall Removal
Size: 5.5 x 12
Design Span (L): 17.25 ft.
Clear Span: 17.00 ft.
Total Span: 17.50 ft.
Selfweight: 266.9 lbs
Dist. Selfweight: 15.47 plf
Total Weight: 270.8 lbs
Beam Design Adam Crosby 57664 Golden Eagle Lane Bend OR 2021A199
3/24/2021 1
3/24/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [66.00 x (207.00 + 3)] x (12 in./ft.)3 = 8.02 ft3
Volumespan = N[A x L] = 1 x [66.00 x 207.00] x (12 in./ft.)3 = 7.91 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.02 = 270.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.91 = 266.9 lbs
  ws = 15.47 plf
17.25 ft.
17.00 ft.
17.50 ft.
1666.65 lbs
1666.65 lbs
3/24/2021 3
fb = = 644.1 psi
 fb = 644.1 psi < Fbx' = 2760.0 psi  (CSI = 0.23)   ➜  OK
3/24/2021 4
fv* = = 33.01 psi
 fv* = 33.01 psi < Fvx' = 304.75 psi  (CSI = 0.11)   ➜  OK
fv = = 37.34 psi
 fv = 37.34 psi < Fvx' = 304.75 psi  (CSI = 0.12)   ➜  OK
3/24/2021 5
ΔLL = = 0.14 in.
(L/d)LL = 207.00 / 0.14 = 1481
 ΔLL = 0.14 in = L/1481 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 207.00 / 0.27 = 778
 ΔTL = 0.27 in = L/778 < L/240   ➜  OK
fc⊥ = = 101.0 psi
 fc⊥ = 101.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.16)   ➜  OK
3/24/2021 6
