Grade: DF No.3
Size: 4 x 4
Design Span (L): 8.00 ft.
Clear Span: 7.75 ft.
Total Span: 8.25 ft.
Live Load: 88 plf
Dead Load: 10 plf
Selfweight: 23.3 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 24.0 lbs
Load Duration: 1.25
Beam Design 2021A197
3/19/2021 1
d = 3.500 in.
DF No.3 900 575 180 625 1350 1600000 580000 0.5
3/19/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (96.00 + 3)] x (12 in./ft.)3 = 0.70 ft3
Volumespan = N[A x L] = 1 x [12.25 x 96.00] x (12 in./ft.)3 = 0.68 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.70 = 24.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.68 = 23.3 lbs
88 plf
10 plf
ws = 2.91 plf
7.75 ft.
8.25 ft.
416.25 lbs
416.25 lbs
3/19/2021 3
Fbx' = (900)(1.25)(1)(1)(1)(1.5)(1)(1) = 1687.5 psi
fb = = 1355.7 psi
 fb = 1355.7 psi < Fbx' = 1687.5 psi  (CSI = 0.80)   ➜  OK
3/19/2021 4
fv* = = 45.82 psi
 fv* = 45.82 psi < Fvx' = 225.00 psi  (CSI = 0.20)   ➜  OK
fv = = 49.43 psi
 fv = 49.43 psi < Fvx' = 225.00 psi  (CSI = 0.22)   ➜  OK
3/19/2021 5
ΔLL = = 0.41 in.
(L/d)LL = 96.00 / 0.41 = 237
 ΔLL = 0.41 in = L/237 < L/180   ➜  OK
ΔTL = = 0.46 in.
(L/d)TL = 96.00 / 0.46 = 207
 ΔTL = 0.46 in = L/207 < L/120   ➜  OK
fc⊥ = = 39.6 psi
 fc⊥ = 39.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.06)   ➜  OK
3/19/2021 6
