Beam Design - 2x10 Purlin at 16 in oc
Design Span (L): 12.38 ft.
Clear Span: 12.25 ft.
Total Span: 12.50 ft.
Bearing (lb): 1.5 in.
Live Load: 81.66 plf
Dead Load: 20 plf
Selfweight: 40.8 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 41.2 lbs
Beam Design Dennis Tarbert 3750 2021-002
3/15/2021 1
3/15/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (148.50 + 1.5)] x (12 in./ft.)3 = 1.20 ft3
Volumespan = N[A x L] = 1 x [13.88 x 148.50] x (12 in./ft.)3 = 1.19 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.20 = 41.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.19 = 40.8 lbs
81.66 plf
20 plf
ws = 3.30 plf
12.38 ft.
12.25 ft.
12.50 ft.
655.97 lbs
655.97 lbs
3/15/2021 3
Fbx' = (900)(1.15)(1)(1)(1)(1.1)(1)(1.15) = 1309.3 psi
fb = = 1127.1 psi
 fb = 1127.1 psi < Fbx' = 1309.3 psi  (CSI = 0.86)   ➜  OK
3/15/2021 4
fv* = = 61.46 psi
 fv* = 61.46 psi < Fvx' = 207.00 psi  (CSI = 0.30)   ➜  OK
fv = = 70.21 psi
 fv = 70.21 psi < Fvx' = 207.00 psi  (CSI = 0.34)   ➜  OK
3/15/2021 5
ΔLL = = 0.27 in.
(L/d)LL = 148.50 / 0.27 = 546
 ΔLL = 0.27 in = L/546 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 148.50 / 0.35 = 424
 ΔTL = 0.35 in = L/424 < L/240   ➜  OK
fc⊥ = = 291.5 psi
 fc⊥ = 291.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.47)   ➜  OK
3/15/2021 6
