Beam Design - Beam
Size: 6.75 x 15
Design Span (L): 27.54 ft.
Clear Span: 27.08 ft.
Total Span: 28.00 ft.
Bearing (lb): 5.5 in.
Selfweight: 1307.6 lbs
Dist. Selfweight: 47.48 plf
Total Weight: 1329.4 lbs
Load Duration: 1.33
CV Volume Factor 0.926b - - - - -
Beam Design John Reynolds Honokaa, Hawaii Newland
3/15/2021 1
b = 6.750 in.
d = 15.000 in.
A = 6.750 x 15.000 = 101.25 in.2
Sx = (6.750)(15.000)2/6 = 253.13 in.3
Sy = (6.750)2(15.000)/6 = 113.91 in.3
Ix = (6.750)(15.000)3/12 = 1898.44 in.4
Iy = (6.750)3(15.000)/12 = 384.43 in.4
3/15/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [101.25 x (330.50 + 5.5)] x (12 in./ft.)3 = 39.38 ft3
Volumespan = N[A x L] = 2 x [101.25 x 330.50] x (12 in./ft.)3 = 38.73 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 39.38 = 1329.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 38.73 = 1307.6 lbs
Distributed Self Weight (ws) = = 47.48 plf
  ws = 47.48 plf
27.54 ft.
27.08 ft.
28.00 ft.
3114.71 lbs
3114.71 lbs
3/15/2021 3
lu = Unbraced Length = 27.542 ft.
lu/d = = 22.03
le = 1.63lu + 3d = 1.63(330.5) + 3(15) = 583.72 in. = 48.64 ft.  (NDS Table 3.3.3)
Rb = = 6.93
 Rb = 6.93 < 50   ➜  OK
3/15/2021 4
FbE = = 21231.01 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.33)(1)(1) = 3192.00 psi
CL =   = 0.991
CV = = 0.926
CV = 0.926 < CL = 0.991
Fbx' = (2400)(1.33)(1)(1)(0.926) = 2955.5 psi
fb = = 500.0 psi
 fb = 500.0 psi < Fbx' = 2955.5 psi  (CSI = 0.17)   ➜  OK
Fvx' = (265)(1.33)(1)(1) = 352.45 psi
fv* = = 20.63 psi
3/15/2021 5
 fv* = 20.63 psi < Fvx' = 352.45 psi  (CSI = 0.06)   ➜  OK
fv = = 22.69 psi
 fv = 22.69 psi < Fvx' = 352.45 psi  (CSI = 0.06)   ➜  OK
ΔLL = = 0.19 in.
(L/d)LL = 330.50 / 0.19 = 1745
 ΔLL = 0.19 in = L/1745 < L/360   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 330.50 / 0.42 = 784
 ΔTL = 0.42 in = L/784 < L/240   ➜  OK
3/15/2021 6
Ab = b x lb = 6.75 x 5.5 = 37.13 in2
fc⊥ = = 41.9 psi
 fc⊥ = 41.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.06)   ➜  OK
3/15/2021 7
