Design Span (L): 7.42 ft.
Clear Span: 7.25 ft.
Total Span: 7.58 ft.
Bearing (lb): 2 in.
Live Load: 474 plf
Dead Load: 178 plf
Selfweight: 59.5 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 60.8 lbs
Defl. Limits: 480|360
Beam Design 2021A185
3/14/2021 1
3/14/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (89.00 + 2)] x (12 in./ft.)3 = 1.78 ft3
Volumespan = N[A x L] = 2 x [16.88 x 89.00] x (12 in./ft.)3 = 1.74 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.78 = 60.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.74 = 59.5 lbs
474 plf
178 plf
ws = 8.02 plf
7.42 ft.
7.25 ft.
7.58 ft.
2502.67 lbs
2502.67 lbs
3/14/2021 3
fb = = 860.7 psi
 fb = 860.7 psi < Fbx' = 900.0 psi  (CSI = 0.96)   ➜  OK
3/14/2021 4
fv* = = 81.28 psi
 fv* = 81.28 psi < Fvx' = 180.00 psi  (CSI = 0.45)   ➜  OK
fv = = 108.79 psi
 fv = 108.79 psi < Fvx' = 180.00 psi  (CSI = 0.60)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
3/14/2021 5
ΔLL = = 0.06 in.
(L/d)LL = 89.00 / 0.06 = 1571
 ΔLL = 0.06 in = L/1571 < L/480   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 89.00 / 0.08 = 1128
 ΔTL = 0.08 in = L/1128 < L/360   ➜  OK
fc⊥ = = 417.1 psi
 fc⊥ = 417.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.67)   ➜  OK
3/14/2021 6
