Beam Design - 2x8 Purlin at 16 in oc
Design Span (L): 12.38 ft.
Clear Span: 12.25 ft.
Total Span: 12.50 ft.
Bearing (lb): 1.5 in.
Live Load: 59.7 plf
Dead Load: 21 plf
Selfweight: 32.0 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 32.3 lbs
Beam Design Justin Fletcher 2425 Mission Creek Road 2021-002
3/13/2021 1
3/13/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (148.50 + 1.5)] x (12 in./ft.)3 = 0.94 ft3
Volumespan = N[A x L] = 1 x [10.88 x 148.50] x (12 in./ft.)3 = 0.93 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.94 = 32.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.93 = 32.0 lbs
59.7 plf
21 plf
ws = 2.58 plf
12.38 ft.
12.25 ft.
12.50 ft.
520.52 lbs
520.52 lbs
3/13/2021 3
Fbx' = (900)(1.15)(1)(1)(1)(1.2)(1)(1.15) = 1428.3 psi
fb = = 1455.9 psi
 fb = 1455.9 psi > Fbx' = 1428.3 psi  (CSI = 1.02)   ➜  NG
3/13/2021 4
fv* = = 64.14 psi
 fv* = 64.14 psi < Fvx' = 207.00 psi  (CSI = 0.31)   ➜  OK
fv = = 71.08 psi
 fv = 71.08 psi < Fvx' = 207.00 psi  (CSI = 0.34)   ➜  OK
3/13/2021 5
ΔLL = = 0.41 in.
(L/d)LL = 148.50 / 0.41 = 359
 ΔLL = 0.41 in = L/359 > L/360   ➜  NG
ΔTL = = 0.58 in.
(L/d)TL = 148.50 / 0.58 = 258
 ΔTL = 0.58 in = L/258 < L/240   ➜  OK
fc⊥ = = 231.3 psi
 fc⊥ = 231.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.37)   ➜  OK
3/13/2021 6
