Beam Design - 2x8 Girt at 2 ft oc
Design Span (L): 12.38 ft.
Clear Span: 12.25 ft.
Total Span: 12.50 ft.
Bearing (lb): 1.5 in.
Live Load: 52 plf
Dead Load: 0 plf
Selfweight: 32.0 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 32.3 lbs
Load Duration: 1.60
Beam Design Justin Fletcher 2425 Mission Creek Road 2021-002
3/13/2021 1
3/13/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (148.50 + 1.5)] x (12 in./ft.)3 = 0.94 ft3
Volumespan = N[A x L] = 1 x [10.88 x 148.50] x (12 in./ft.)3 = 0.93 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.94 = 32.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.93 = 32.0 lbs
52 plf
0 plf
ws = 2.58 plf
12.38 ft.
12.25 ft.
12.50 ft.
341.14 lbs
341.14 lbs
3/13/2021 3
Fbx' = (900)(1.60)(1)(1)(1)(1.2)(1)(1.15) = 1987.2 psi
fb = = 954.2 psi
 fb = 954.2 psi < Fbx' = 1987.2 psi  (CSI = 0.48)   ➜  OK
3/13/2021 4
Fvx' = (180)(1.60)(1)(1)(1) = 288.00 psi
fv* = = 42.04 psi
 fv* = 42.04 psi < Fvx' = 288.00 psi  (CSI = 0.15)   ➜  OK
fv = = 46.58 psi
 fv = 46.58 psi < Fvx' = 288.00 psi  (CSI = 0.16)   ➜  OK
3/13/2021 5
ΔLL = = 0.36 in.
(L/d)LL = 148.50 / 0.36 = 412
 ΔLL = 0.36 in = L/412 < L/360   ➜  OK
ΔTL = = 0.38 in.
(L/d)TL = 148.50 / 0.38 = 393
 ΔTL = 0.38 in = L/393 < L/240   ➜  OK
fc⊥ = = 151.6 psi
 fc⊥ = 151.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.24)   ➜  OK
3/13/2021 6
