Design Span (L): 5.88 ft.
Clear Span: 5.75 ft.
Total Span: 6.00 ft.
Bearing (lb): 1.5 in.
Live Load: 30 plf
Dead Load: 60 plf
Selfweight: 23.0 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 23.5 lbs
Beam Design 2021A18
1/6/2021 1
Beam Design 2021A18
1/6/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (70.50 + 1.5)] x (12 in./ft.)3 = 0.69 ft3
Volumespan = N[A x L] = 2 x [8.25 x 70.50] x (12 in./ft.)3 = 0.67 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.69 = 23.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.67 = 23.0 lbs
30 plf
60 plf
ws = 3.92 plf
5.88 ft.
5.75 ft.
281.76 lbs
281.76 lbs
Beam Design 2021A18
1/6/2021 3
fb = = 321.5 psi
 fb = 321.5 psi < Fbx' = 1345.5 psi  (CSI = 0.24)   ➜  OK
Beam Design 2021A18
1/6/2021 4
fv* = = 21.17 psi
 fv* = 21.17 psi < Fvx' = 207.00 psi  (CSI = 0.10)   ➜  OK
fv = = 25.08 psi
 fv = 25.08 psi < Fvx' = 207.00 psi  (CSI = 0.12)   ➜  OK
Beam Design 2021A18
1/6/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 70.50 / 0.01 = 5834
 ΔLL = 0.01 in = L/5834 < L/180   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 70.50 / 0.04 = 1864
 ΔTL = 0.04 in = L/1864 < L/120   ➜  OK
fc⊥ = = 62.6 psi
 fc⊥ = 62.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
Beam Design 2021A18
1/6/2021 6
