Grade: SPF No.1
Size: 2 x 4
Design Span (L): 2.33 ft.
Clear Span: 2.17 ft.
Total Span: 2.50 ft.
Bearing (lb): 2 in.
Live Load: 150 plf
Dead Load: 20 plf
Selfweight: 2.5 lbs
Dist. Selfweight: 1.06 plf
Total Weight: 2.7 lbs
Orientation: Horizontal
Beam Design 2021A176
3/12/2021 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SPF No.1 875 450 135 425 1150 1400000 510000 0.42
3/12/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (28.00 + 2)] x (12 in./ft.)3 = 0.09 ft3
Volumespan = N[A x L] = 1 x [5.25 x 28.00] x (12 in./ft.)3 = 0.09 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.09 = 2.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.09 = 2.5 lbs
Distributed Self Weight (ws) = = 1.06 plf
150 plf
20 plf
ws = 1.06 plf
2.33 ft.
2.17 ft.
2.50 ft.
213.80 lbs
213.80 lbs
3/12/2021 3
Fby' = (875)(1.00)(1)(1)(1)(1.5)(1.1)(1)(1) = 1443.8 psi
fb = = 1064.1 psi
 fb = 1064.1 psi < Fby' = 1443.8 psi  (CSI = 0.74)   ➜  OK
3/12/2021 4
Fvy' = (135)(1.00)(1)(1)(1) = 135.00 psi
fv* = = 50.90 psi
 fv* = 50.90 psi < Fvy' = 135.00 psi  (CSI = 0.38)   ➜  OK
fv = = 57.01 psi
 fv = 57.01 psi < Fvy' = 135.00 psi  (CSI = 0.42)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(1)(1)(1) = 1400000 psi
3/12/2021 5
ΔLL = = 0.07 in.
(L/d)LL = 28.00 / 0.07 = 386
 ΔLL = 0.07 in = L/386 < L/360   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 28.00 / 0.08 = 338
 ΔTL = 0.08 in = L/338 < L/240   ➜  OK
Fc⊥y' = (425)(1)(1)(1) = 425.00 psi
Ab = d x lb = 3.5 x 2 = 7.00 in2
fc⊥ = = 30.5 psi
 fc⊥ = 30.5 psi < Fc⊥y' = 425.00 psi  (CSI = 0.07)   ➜  OK
3/12/2021 6
