Grade: 24F-V8 1.8E DF/DF
Size: 6.75 x 9
Design Span (L): 10.50 ft.
Clear Span: 10.00 ft.
Total Span: 11.00 ft.
Live Load: 1000 lbs
Dead Load: 7000 lbs
Selfweight: 149.6 lbs
Dist. Selfweight: 14.24 plf
Total Weight: 156.7 lbs
Beam Design 2021A173
3/9/2021 1
b = 6.750 in.
d = 9.000 in.
A = 6.750 x 9.000 = 60.75 in.2
Sx = (6.750)(9.000)2/6 = 91.13 in.3
Sy = (6.750)2(9.000)/6 = 68.34 in.3
Ix = (6.750)(9.000)3/12 = 410.06 in.4
Iy = (6.750)3(9.000)/12 = 230.66 in.4
3/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [60.75 x (126.00 + 6)] x (12 in./ft.)3 = 4.64 ft3
Volumespan = N[A x L] = 1 x [60.75 x 126.00] x (12 in./ft.)3 = 4.43 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.64 = 156.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.43 = 149.6 lbs
Distributed Self Weight (ws) = = 14.24 plf
1000 lbs
7000 lbs
  ws = 14.24 plf
10.50 ft.
10.00 ft.
11.00 ft.
4078.34 lbs
4078.34 lbs
3/9/2021 3
lu = Unbraced Length = 10.500 ft.
lu/d = = 14.00
le = 1.37lu + 3d = 1.37(126.0) + 3(9) = 199.62 in. = 16.64 ft.  (NDS Table 3.3.3)
Rb = = 6.28
 Rb = 6.28 < 50   ➜  OK
3/9/2021 4
FbE = = 25867.90 psi
CL =   = 0.994
CL = 0.994 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.994) = 2743.7 psi
fb = = 2791.3 psi
 fb = 2791.3 psi > Fbx' = 2743.7 psi  (CSI = 1.02)   ➜  NG
fv* = = 100.35 psi
3/9/2021 5
 fv* = 100.35 psi < Fvx' = 304.75 psi  (CSI = 0.33)   ➜  OK
fv = = 100.61 psi
 fv = 100.61 psi < Fvx' = 304.75 psi  (CSI = 0.33)   ➜  OK
ΔLL =   =   = 0.06 in.
(L/d)LL = 126.00 / 0.06 = 2232
 ΔLL = 0.06 in = L/2232 < L/360   ➜  OK
ΔTL =   =   = 0.46 in.
(L/d)TL = 126.00 / 0.46 = 276
 ΔTL = 0.46 in = L/276 < L/240   ➜  OK
3/9/2021 6
fc⊥ = = 100.7 psi
 fc⊥ = 100.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.15)   ➜  OK
3/9/2021 7
