Size: 4 x 6
Design Span (L): 4.15 ft.
Clear Span: 3.90 ft.
Total Span: 4.40 ft.
Live Load: 50 plf
Dead Load: 300 plf
Selfweight: 38.0 lbs
Dist. Selfweight: 9.14 plf
Total Weight: 40.2 lbs
Orientation: Horizontal
Beam Design 2021A168
3/8/2021 1
3/8/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [19.25 x (49.80 + 3)] x (12 in./ft.)3 = 1.18 ft3
Volumespan = N[A x L] = 2 x [19.25 x 49.80] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.18 = 40.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.11 = 38.0 lbs
Distributed Self Weight (ws) = = 9.14 plf
50 plf
300 plf
ws = 9.14 plf
4.15 ft.
3.90 ft.
4.40 ft.
790.12 lbs
790.12 lbs
3/8/2021 3
Fby' = (900)(1.15)(1)(1)(1)(1.3)(1.05)(1)(1) = 1412.8 psi
fb = = 413.1 psi
 fb = 413.1 psi < Fby' = 1412.8 psi  (CSI = 0.29)   ➜  OK
3/8/2021 4
fv* = = 24.95 psi
 fv* = 24.95 psi < Fvy' = 207.00 psi  (CSI = 0.12)   ➜  OK
fv = = 29.03 psi
 fv = 29.03 psi < Fvy' = 207.00 psi  (CSI = 0.14)   ➜  OK
3/8/2021 5
ΔLL = = 0.01 in.
(L/d)LL = 49.80 / 0.01 = 9385
 ΔLL = 0.01 in = L/9385 < L/180   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 49.80 / 0.04 = 1307
 ΔTL = 0.04 in = L/1307 < L/120   ➜  OK
Ab = d x lb = 5.5 x 3 = 16.50 in2
fc⊥ = = 23.9 psi
 fc⊥ = 23.9 psi < Fc⊥y' = 625.00 psi  (CSI = 0.04)   ➜  OK
3/8/2021 6
