Species: Hem-Fir
Grade: HF No.2
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Live Load: 32 plf
Dead Load: 127 plf
Selfweight: 30.5 lbs
Dist. Selfweight: 3.49 plf
Total Weight: 31.4 lbs
Beam Design 2021A164
3/6/2021 1
G = 0.43
3/6/2021 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (105.00 + 3)] x (12 in./ft.)3 = 1.05 ft3
Volumespan = N[A x L] = 1 x [16.88 x 105.00] x (12 in./ft.)3 = 1.03 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 1.05 = 31.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 1.03 = 30.5 lbs
Distributed Self Weight (ws) = = 3.49 plf
32 plf
127 plf
ws = 3.49 plf
8.75 ft.
8.50 ft.
9.00 ft.
731.18 lbs
731.18 lbs
3/6/2021 3
Fbx' = (850)(1.15)(1)(1)(1)(1)(1)(1) = 977.5 psi
fb = = 589.8 psi
 fb = 589.8 psi < Fbx' = 977.5 psi  (CSI = 0.60)   ➜  OK
3/6/2021 4
Fvx' = (150)(1.15)(1)(1)(1) = 172.50 psi
fv* = = 49.65 psi
 fv* = 49.65 psi < Fvx' = 172.50 psi  (CSI = 0.29)   ➜  OK
fv = = 63.19 psi
 fv = 63.19 psi < Fvx' = 172.50 psi  (CSI = 0.37)   ➜  OK
3/6/2021 5
ΔLL = = 0.02 in.
(L/d)LL = 105.00 / 0.02 = 5756
 ΔLL = 0.02 in = L/5756 < L/180   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 105.00 / 0.09 = 1134
 ΔTL = 0.09 in = L/1134 < L/120   ➜  OK
fc⊥ = = 162.5 psi
 fc⊥ = 162.5 psi < Fc⊥x' = 405.00 psi  (CSI = 0.40)   ➜  OK
3/6/2021 6
