Beam Design - mellion
Grade: SP DSS
Size: 4 x 6
Design Span (L): 7.25 ft.
Clear Span: 7.00 ft.
Total Span: 7.50 ft.
Selfweight: 36.2 lbs
Dist. Selfweight: 4.99 plf
Total Weight: 37.4 lbs
Beam Design Joe Sykes 50 Story Road 1
3/4/2021 1
SP DSS 2400 1650 175 660 1900 1900000 690000 0.55
3/4/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (87.00 + 3)] x (12 in./ft.)3 = 1.00 ft3
Volumespan = N[A x L] = 1 x [19.25 x 87.00] x (12 in./ft.)3 = 0.97 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.00 = 37.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.97 = 36.2 lbs
Distributed Self Weight (ws) = = 4.99 plf
ws = 4.99 plf
7.25 ft.
7.00 ft.
7.50 ft.
674.96 lbs
674.96 lbs
3/4/2021 3
Fbx' = (2400)(1.15)(1)(1)(1)(1)(1)(1) = 2760.0 psi
fb = = 804.2 psi
 fb = 804.2 psi < Fbx' = 2760.0 psi  (CSI = 0.29)   ➜  OK
3/4/2021 4
fv* = = 44.41 psi
 fv* = 44.41 psi < Fvx' = 201.25 psi  (CSI = 0.22)   ➜  OK
fv = = 50.84 psi
 fv = 50.84 psi < Fvx' = 201.25 psi  (CSI = 0.25)   ➜  OK
3/4/2021 5
ΔLL = = 0.07 in.
(L/d)LL = 87.00 / 0.07 = 1290
 ΔLL = 0.07 in = L/1290 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 87.00 / 0.12 = 717
 ΔTL = 0.12 in = L/717 < L/240   ➜  OK
fc⊥ = = 64.3 psi
 fc⊥ = 64.3 psi < Fc⊥x' = 660.00 psi  (CSI = 0.10)   ➜  OK
3/4/2021 6
