Live Load: plf
Selfweight: 154.2 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 157.5 lbs
Orientation: Horizontal
Beam Design tracy rodriguez 120 main street tro
3/1/2021 1
3/1/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 4.22 ft3
Volumespan = N[A x L] = 3 x [16.88 x 141.00] x (12 in./ft.)3 = 4.13 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 4.22 = 157.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 4.13 = 154.2 lbs
plf
ws = 13.12 plf
528.74 lbs
528.74 lbs
3/1/2021 3
Fby' = (750)(1.00)(1)(1)(1)(1)(1.2)(1)(1.15) = 1035.0 psi
fb = = 1442.0 psi
 fb = 1442.0 psi > Fby' = 1035.0 psi  (CSI = 1.39)   ➜  NG
3/1/2021 4
Fvy' = (175)(1.00)(1)(1)(1) = 175.00 psi
fv* = = 15.01 psi
 fv* = 15.01 psi < Fvy' = 175.00 psi  (CSI = 0.09)   ➜  OK
fv = = 15.34 psi
 fv = 15.34 psi < Fvy' = 175.00 psi  (CSI = 0.09)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(1)(1)(1) = 1400000 psi
3/1/2021 5
ΔLL = = 0.00 in.
(L/d)LL = 141.00 / 0.00 = ∞
ΔTL = = 2.84 in.
(L/d)TL = 141.00 / 2.84 = 50
 ΔTL = 2.84 in = L/50 > L/240   ➜  NG
Fc⊥y' = (565)(1)(1)(1) = 565.00 psi
Ab = d x lb = 11.25 x 3 = 33.75 in2
fc⊥ = = 5.2 psi
 fc⊥ = 5.2 psi < Fc⊥y' = 565.00 psi  (CSI = 0.01)   ➜  OK
3/1/2021 6
