Size: 5.5 x 13.5
Design Span (L): 21.54 ft.
Clear Span: 21.08 ft.
Total Span: 22.00 ft.
Bearing (lb): 5.5 in.
Live Load: 257 plf
Dead Load: 138 plf
Selfweight: 394.0 lbs
Dist. Selfweight: 18.29 plf
Total Weight: 402.3 lbs
CV Volume Factor 0.979b - - - - -
Beam Design 2021A154
3/1/2021 1
d = 13.500 in.
3/1/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (258.50 + 5.5)] x (12 in./ft.)3 = 11.34 ft3
Volumespan = N[A x L] = 1 x [74.25 x 258.50] x (12 in./ft.)3 = 11.11 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 11.34 = 402.3 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 11.11 = 394.0 lbs
Distributed Self Weight (ws) = = 18.29 plf
257 plf
138 plf
  ws = 18.29 plf
21.54 ft.
21.08 ft.
22.00 ft.
4546.23 lbs
4546.23 lbs
3/1/2021 3
lu/d = = 1.78
Rb = = 4.70
 Rb = 4.70 < 50   ➜  OK
3/1/2021 4
FbE = = 38508.65 psi
CL =   = 0.997
CV = = 0.979
CV = 0.979 < CL = 0.997
Fbx' = (2400)(1.15)(0.8)(1)(0.979) = 2161.3 psi
fb = = 1722.0 psi
 fb = 1722.0 psi < Fbx' = 2161.3 psi  (CSI = 0.80)   ➜  OK
fv* = = 80.54 psi
3/1/2021 5
 fv* = 80.54 psi < Fvx' = 266.66 psi  (CSI = 0.30)   ➜  OK
fv = = 89.93 psi
 fv = 89.93 psi < Fvx' = 266.66 psi  (CSI = 0.34)   ➜  OK
ΔLL = = 0.74 in.
(L/d)LL = 258.50 / 0.74 = 351
 ΔLL = 0.74 in = L/351 < L/180   ➜  OK
ΔTL = = 1.18 in.
(L/d)TL = 258.50 / 1.18 = 218
 ΔTL = 1.18 in = L/218 < L/120   ➜  OK
3/1/2021 6
fc⊥ = = 150.3 psi
 fc⊥ = 150.3 psi < Fc⊥x' = 344.50 psi  (CSI = 0.44)   ➜  OK
3/1/2021 7
