Size: 5.5 x 15
Design Span (L): 27.67 ft.
Clear Span: 27.33 ft.
Total Span: 28.00 ft.
Bearing (lb): 4 in.
Live Load: 210 plf
Dead Load: 55 plf
Selfweight: 535.1 lbs
Dist. Selfweight: 19.34 plf
Total Weight: 541.6 lbs
CV Volume Factor 0.945b - - - - -
Beam Design 2021A146
2/26/2021 1
d = 15.000 in.
A = 5.500 x 15.000 = 82.50 in.2
Sx = (5.500)(15.000)2/6 = 206.25 in.3
Sy = (5.500)2(15.000)/6 = 75.63 in.3
Ix = (5.500)(15.000)3/12 = 1546.88 in.4
Iy = (5.500)3(15.000)/12 = 207.97 in.4
2/26/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [82.50 x (332.00 + 4)] x (12 in./ft.)3 = 16.04 ft3
Volumespan = N[A x L] = 1 x [82.50 x 332.00] x (12 in./ft.)3 = 15.85 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 16.04 = 541.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 15.85 = 535.1 lbs
Distributed Self Weight (ws) = = 19.34 plf
210 plf
55 plf
  ws = 19.34 plf
27.67 ft.
27.33 ft.
28.00 ft.
3980.84 lbs
3980.84 lbs
2/26/2021 3
CV = = 0.945
CV = 0.945 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.945) = 2267.1 psi
fb = = 1582.9 psi
 fb = 1582.9 psi < Fbx' = 2267.1 psi  (CSI = 0.70)   ➜  OK
2/26/2021 4
fv* = = 65.05 psi
 fv* = 65.05 psi < Fvx' = 265.00 psi  (CSI = 0.25)   ➜  OK
fv = = 71.52 psi
 fv = 71.52 psi < Fvx' = 265.00 psi  (CSI = 0.27)   ➜  OK
2/26/2021 5
ΔLL = = 0.99 in.
(L/d)LL = 332.00 / 0.99 = 334
 ΔLL = 0.99 in = L/334 > L/360   ➜  NG
ΔTL = = 1.35 in.
(L/d)TL = 332.00 / 1.35 = 247
 ΔTL = 1.35 in = L/247 < L/240   ➜  OK
Ab = b x lb = 5.5 x 4 = 22.00 in2
fc⊥ = = 180.9 psi
 fc⊥ = 180.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.28)   ➜  OK
2/26/2021 6
