Grade: SPF Stud
Size: 2 x 4
Design Span (L): 1.33 ft.
Clear Span: 1.27 ft.
Total Span: 1.39 ft.
Bearing (lb): .75 in.
Live Load: 310 lbs
Dead Load: 74 lbs
Selfweight: 2.8 lbs
Dist. Selfweight: 2.12 plf
Total Weight: 3.0 lbs
Orientation: Horizontal
CF Size Factor 1.1 1.1 - 1.05 - -
Beam Design 2021A145
2/25/2021 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
SPF Stud 675 350 135 425 725 1200000 440000 0.42
2/25/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [5.25 x (15.96 + .75)] x (12 in./ft.)3 = 0.10 ft3
Volumespan = N[A x L] = 2 x [5.25 x 15.96] x (12 in./ft.)3 = 0.10 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.10 = 3.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.10 = 2.8 lbs
Distributed Self Weight (ws) = = 2.12 plf
310 lbs
74 lbs
ws = 2.12 plf
1.33 ft.
1.27 ft.
1.39 ft.
193.48 lbs
193.48 lbs
2/25/2021 3
Fby' = (675)(1.15)(1)(1)(1)(1.1)(1.1)(1)(1) = 939.3 psi
fb = = 585.8 psi
 fb = 585.8 psi < Fby' = 939.3 psi  (CSI = 0.62)   ➜  OK
2/25/2021 4
Fvy' = (135)(1.15)(1)(1)(1) = 155.25 psi
fv* = = 27.59 psi
 fv* = 27.59 psi < Fvy' = 155.25 psi  (CSI = 0.18)   ➜  OK
fv = = 27.63 psi
 fv = 27.63 psi < Fvy' = 155.25 psi  (CSI = 0.18)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1200000(1)(1)(1) = 1200000 psi
2/25/2021 5
ΔLL =   =   = 0.01 in.
(L/d)LL = 15.96 / 0.01 = 1436
 ΔLL = 0.01 in = L/1436 < L/240   ➜  OK
ΔTL =   =   = 0.01 in.
(L/d)TL = 15.96 / 0.01 = 1154
 ΔTL = 0.01 in = L/1154 < L/180   ➜  OK
Fc⊥y' = (425)(1)(1)(1) = 425.00 psi
Ab = d x lb = 3.5 x .75 = 2.63 in2
fc⊥ = = 36.9 psi
 fc⊥ = 36.9 psi < Fc⊥y' = 425.00 psi  (CSI = 0.09)   ➜  OK
2/25/2021 6
