Beam Design - Tosco Pizza
Design Span (L): 12.65 ft.
Clear Span: 12.57 ft.
Total Span: 12.73 ft.
Bearing (lb): 1 in.
Live Load: 669 lbs
Dead Load: 1 lbs
Selfweight: 41.7 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 42.0 lbs
Load Duration: 1.60
Beam Design Dennis Lowenwirth 2021A138
2/16/2021 1
2/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (151.80 + 1)] x (12 in./ft.)3 = 1.23 ft3
Volumespan = N[A x L] = 1 x [13.88 x 151.80] x (12 in./ft.)3 = 1.22 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.23 = 42.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.22 = 41.7 lbs
669 lbs
1 lbs
ws = 3.30 plf
12.65 ft.
12.57 ft.
12.73 ft.
355.98 lbs
355.98 lbs
2/16/2021 3
Fbx' = (900)(1.60)(1)(1)(1)(1.1)(1)(1) = 1584.0 psi
fb = = 1225.7 psi
 fb = 1225.7 psi < Fbx' = 1584.0 psi  (CSI = 0.77)   ➜  OK
2/16/2021 4
Fvx' = (180)(1.60)(1)(1)(1) = 288.00 psi
fv* = = 38.20 psi
 fv* = 38.20 psi < Fvx' = 288.00 psi  (CSI = 0.13)   ➜  OK
fv = = 38.47 psi
 fv = 38.47 psi < Fvx' = 288.00 psi  (CSI = 0.13)   ➜  OK
2/16/2021 5
ΔLL =   =   = 0.31 in.
(L/d)LL = 151.80 / 0.31 = 493
 ΔLL = 0.31 in = L/493 < L/180   ➜  OK
ΔTL =   =   = 0.32 in.
(L/d)TL = 151.80 / 0.32 = 474
 ΔTL = 0.32 in = L/474 < L/120   ➜  OK
Ab = b x lb = 1.5 x 1 = 1.50 in2
fc⊥ = = 237.3 psi
 fc⊥ = 237.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.38)   ➜  OK
2/16/2021 6
