Beam Design - KITCHEN BEAM
Size: 3.5 x 9
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 75 plf
Dead Load: 20 plf
Selfweight: 123.7 lbs
Dist. Selfweight: 7.39 plf
Total Weight: 125.5 lbs
Defl. Limits: 480|360
Beam Design BILL WRIGHT 2021A135
2/16/2021 1
d = 9.000 in.
2/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [31.50 x (201.00 + 3)] x (12 in./ft.)3 = 3.72 ft3
Volumespan = N[A x L] = 1 x [31.50 x 201.00] x (12 in./ft.)3 = 3.66 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.72 = 125.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.66 = 123.7 lbs
20 plf
  ws = 7.39 plf
16.75 ft.
16.50 ft.
17.00 ft.
870.27 lbs
870.27 lbs
2/16/2021 3
fb = = 911.9 psi
 fb = 911.9 psi < Fbx' = 2760.0 psi  (CSI = 0.33)   ➜  OK
2/16/2021 4
fv* = = 37.18 psi
 fv* = 37.18 psi < Fvx' = 304.75 psi  (CSI = 0.12)   ➜  OK
fv = = 40.83 psi
 fv = 40.83 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
2/16/2021 5
ΔLL = = 0.35 in.
(L/d)LL = 201.00 / 0.35 = 579
 ΔLL = 0.35 in = L/579 < L/480   ➜  OK
ΔTL = = 0.47 in.
(L/d)TL = 201.00 / 0.47 = 424
 ΔTL = 0.47 in = L/424 < L/360   ➜  OK
fc⊥ = = 82.9 psi
 fc⊥ = 82.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.13)   ➜  OK
2/16/2021 6
