Size: 4 x 8
Design Span (L): 16.75 ft.
Clear Span: 16.50 ft.
Total Span: 17.00 ft.
Live Load: 30 lbs
Dead Load: 15 lbs
Selfweight: 101.0 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 102.5 lbs
Beam Design 2021A134
2/16/2021 1
2/16/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (201.00 + 3)] x (12 in./ft.)3 = 3.00 ft3
Volumespan = N[A x L] = 1 x [25.38 x 201.00] x (12 in./ft.)3 = 2.95 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.00 = 102.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.95 = 101.0 lbs
30 lbs
15 lbs
ws = 6.03 plf
16.75 ft.
16.50 ft.
17.00 ft.
73.73 lbs
73.73 lbs
2/16/2021 3
fb = = 156.5 psi
 fb = 156.5 psi < Fbx' = 1345.5 psi  (CSI = 0.12)   ➜  OK
2/16/2021 4
fv* = = 4.10 psi
 fv* = 4.10 psi < Fvx' = 207.00 psi  (CSI = 0.02)   ➜  OK
fv = = 4.31 psi
 fv = 4.31 psi < Fvx' = 207.00 psi  (CSI = 0.02)   ➜  OK
2/16/2021 5
ΔLL =   =   = 0.03 in.
(L/d)LL = 201.00 / 0.03 = 7043
 ΔLL = 0.03 in = L/7043 < L/360   ➜  OK
ΔTL =   =   = 0.10 in.
(L/d)TL = 201.00 / 0.10 = 1955
 ΔTL = 0.10 in = L/1955 < L/240   ➜  OK
fc⊥ = = 7.0 psi
 fc⊥ = 7.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.01)   ➜  OK
2/16/2021 6
