Beam Design - Tosco Pizza
Grade: SPF No.2
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 769 lbs
Dead Load: 1 lbs
Selfweight: 38.6 lbs
Dist. Selfweight: 2.80 plf
Total Weight: 39.3 lbs
Load Duration: 1.60
Beam Design 2021A131
2/13/2021 1
2/13/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (165.00 + 3)] x (12 in./ft.)3 = 1.35 ft3
Volumespan = N[A x L] = 1 x [13.88 x 165.00] x (12 in./ft.)3 = 1.32 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.35 = 39.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.32 = 38.6 lbs
Distributed Self Weight (ws) = = 2.80 plf
769 lbs
1 lbs
ws = 2.80 plf
13.75 ft.
13.50 ft.
404.63 lbs
404.63 lbs
2/13/2021 3
Fbx' = (875)(1.60)(1)(1)(1)(1.1)(1)(1) = 1540.0 psi
fb = = 1522.1 psi
 fb = 1522.1 psi < Fbx' = 1540.0 psi  (CSI = 0.99)   ➜  OK
2/13/2021 4
Fvx' = (135)(1.60)(1)(1)(1) = 216.00 psi
fv* = = 43.47 psi
 fv* = 43.47 psi < Fvx' = 216.00 psi  (CSI = 0.20)   ➜  OK
fv = = 43.71 psi
 fv = 43.71 psi < Fvx' = 216.00 psi  (CSI = 0.20)   ➜  OK
2/13/2021 5
ΔLL =   =   = 0.52 in.
(L/d)LL = 165.00 / 0.52 = 318
 ΔLL = 0.52 in = L/318 > L/360   ➜  NG
ΔTL =   =   = 0.54 in.
(L/d)TL = 165.00 / 0.54 = 308
 ΔTL = 0.54 in = L/308 < L/240   ➜  OK
fc⊥ = = 89.9 psi
 fc⊥ = 89.9 psi < Fc⊥x' = 425.00 psi  (CSI = 0.21)   ➜  OK
2/13/2021 6
