Beam Design - Healy Kitchen Beam Calc
Grade: DF SS
Size: 4 x 8
Design Span (L): 4.96 ft.
Clear Span: 4.83 ft.
Total Span: 5.08 ft.
Bearing (lb): 1.5 in.
Live Load: 1900 lbs
Dead Load: 950 lbs
Selfweight: 29.9 lbs
Dist. Selfweight: 6.03 plf
Total Weight: 30.6 lbs
Beam Design 2021A123
2/9/2021 1
2/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (59.46 + 1.5)] x (12 in./ft.)3 = 0.90 ft3
Volumespan = N[A x L] = 1 x [25.38 x 59.46] x (12 in./ft.)3 = 0.87 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.90 = 30.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.87 = 29.9 lbs
1900 lbs
950 lbs
ws = 6.03 plf
4.96 ft.
4.83 ft.
5.08 ft.
1440.31 lbs
1440.31 lbs
2/9/2021 3
Fbx' = (1500)(1.00)(1)(1)(1)(1.3)(1)(1) = 1950.0 psi
fb = = 1388.9 psi
 fb = 1388.9 psi < Fbx' = 1950.0 psi  (CSI = 0.71)   ➜  OK
2/9/2021 4
fv* = = 84.90 psi
 fv* = 84.90 psi < Fvx' = 180.00 psi  (CSI = 0.47)   ➜  OK
fv = = 85.12 psi
 fv = 85.12 psi < Fvx' = 180.00 psi  (CSI = 0.47)   ➜  OK
2/9/2021 5
ΔLL =   =   = 0.04 in.
(L/d)LL = 59.46 / 0.04 = 1509
 ΔLL = 0.04 in = L/1509 < L/360   ➜  OK
ΔTL =   =   = 0.06 in.
(L/d)TL = 59.46 / 0.06 = 999
 ΔTL = 0.06 in = L/999 < L/240   ➜  OK
Ab = b x lb = 3.5 x 1.5 = 5.25 in2
fc⊥ = = 274.3 psi
 fc⊥ = 274.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.44)   ➜  OK
2/9/2021 6
