Beam Design - Healy Kitchen Beam Calc
Grade: DF SS
Size: 4 x 6
Design Span (L): 4.96 ft.
Clear Span: 4.83 ft.
Total Span: 5.08 ft.
Bearing (lb): 1.5 in.
Live Load: 1900 lbs
Dead Load: 950 lbs
Selfweight: 22.7 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 23.2 lbs
Beam Design 2021A122
2/9/2021 1
2/9/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (59.46 + 1.5)] x (12 in./ft.)3 = 0.68 ft3
Volumespan = N[A x L] = 1 x [19.25 x 59.46] x (12 in./ft.)3 = 0.66 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.68 = 23.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.66 = 22.7 lbs
1900 lbs
950 lbs
ws = 4.57 plf
4.96 ft.
4.83 ft.
5.08 ft.
1436.61 lbs
1436.61 lbs
2/9/2021 3
Fbx' = (1500)(1.00)(1)(1)(1)(1.3)(1)(1) = 1950.0 psi
fb = = 2410.4 psi
 fb = 2410.4 psi > Fbx' = 1950.0 psi  (CSI = 1.24)   ➜  NG
2/9/2021 4
fv* = = 111.76 psi
 fv* = 111.76 psi < Fvx' = 180.00 psi  (CSI = 0.62)   ➜  OK
fv = = 111.92 psi
 fv = 111.92 psi < Fvx' = 180.00 psi  (CSI = 0.62)   ➜  OK
2/9/2021 5
ΔLL =   =   = 0.09 in.
(L/d)LL = 59.46 / 0.09 = 659
 ΔLL = 0.09 in = L/659 < L/360   ➜  OK
ΔTL =   =   = 0.14 in.
(L/d)TL = 59.46 / 0.14 = 437
 ΔTL = 0.14 in = L/437 < L/240   ➜  OK
Ab = b x lb = 3.5 x 1.5 = 5.25 in2
fc⊥ = = 273.6 psi
 fc⊥ = 273.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.44)   ➜  OK
2/9/2021 6
