Design Span (L): 6.54 ft.
Clear Span: 6.00 ft.
Total Span: 7.08 ft.
Bearing (lb): 6.5 in.
Live Load: 1500 lbs
Dead Load: 181 lbs
Selfweight: 33.8 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 36.6 lbs
Load Duration: 1.25
Beam Design 2021A121
2/9/2021 1
2/9/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (78.50 + 6.5)] x (12 in./ft.)3 = 1.07 ft3
Volumespan = N[A x L] = 2 x [10.88 x 78.50] x (12 in./ft.)3 = 0.99 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.07 = 36.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.99 = 33.8 lbs
1500 lbs
181 lbs
ws = 5.17 plf
6.54 ft.
7.08 ft.
858.80 lbs
858.80 lbs
2/9/2021 3
Fbx' = (900)(1.25)(1)(1)(1)(1.2)(1)(1) = 1350.0 psi
fb = = 1267.9 psi
 fb = 1267.9 psi < Fbx' = 1350.0 psi  (CSI = 0.94)   ➜  OK
2/9/2021 4
fv* = = 58.92 psi
 fv* = 58.92 psi < Fvx' = 225.00 psi  (CSI = 0.26)   ➜  OK
fv = = 59.13 psi
 fv = 59.13 psi < Fvx' = 225.00 psi  (CSI = 0.26)   ➜  OK
2/9/2021 5
ΔLL =   =   = 0.10 in.
(L/d)LL = 78.50 / 0.10 = 791
 ΔLL = 0.10 in = L/791 < L/180   ➜  OK
ΔTL =   =   = 0.11 in.
(L/d)TL = 78.50 / 0.11 = 697
 ΔTL = 0.11 in = L/697 < L/120   ➜  OK
Ab = b x lb = 1.5 x 6.5 = 9.75 in2
fc⊥ = = 44.0 psi
 fc⊥ = 44.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
2/9/2021 6
