Design Span (L): 4.54 ft.
Clear Span: 4.42 ft.
Total Span: 4.67 ft.
Bearing (lb): 1.5 in.
Dead Load: 15 plf
Selfweight: 9.2 lbs
Dist. Selfweight: 2.03 plf
Total Weight: 9.5 lbs
Incised Lumber: Yes
Beam Design Kiva Lints 31307 NE 144TH ST Archery Target
2/7/2021 1
2/7/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (54.54 + 1.5)] x (12 in./ft.)3 = 0.27 ft3
Volumespan = N[A x L] = 1 x [8.25 x 54.54] x (12 in./ft.)3 = 0.26 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.27 = 9.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.26 = 9.2 lbs
Distributed Self Weight (ws) = = 2.03 plf
15 plf
ws = 2.03 plf
4.54 ft.
4.42 ft.
4.67 ft.
273.27 lbs
273.27 lbs
2/7/2021 3
Fbx' = (900)(1.00)(0.85)(1)(1)(1.3)(0.8)(1) = 795.6 psi
fb = = 479.5 psi
 fb = 479.5 psi < Fbx' = 795.6 psi  (CSI = 0.60)   ➜  OK
2/7/2021 4
Fvx' = (180)(1.00)(0.97)(1)(0.8) = 139.68 psi
fv* = = 38.60 psi
 fv* = 38.60 psi < Fvx' = 139.68 psi  (CSI = 0.28)   ➜  OK
fv = = 48.36 psi
 fv = 48.36 psi < Fvx' = 139.68 psi  (CSI = 0.35)   ➜  OK
2/7/2021 5
ΔLL = = 0.03 in.
(L/d)LL = 54.54 / 0.03 = 1616
 ΔLL = 0.03 in = L/1616 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 54.54 / 0.04 = 1381
 ΔTL = 0.04 in = L/1381 < L/240   ➜  OK
fc⊥ = = 121.5 psi
 fc⊥ = 121.5 psi < Fc⊥x' = 418.75 psi  (CSI = 0.29)   ➜  OK
2/7/2021 6
