Size: 5.125 x 12
Design Span (L): 12.71 ft.
Clear Span: 12.25 ft.
Total Span: 13.17 ft.
Bearing (lb): 5.5 in.
Live Load: 435 plf
Dead Load: 270 plf
Selfweight: 183.2 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 189.8 lbs
Defl. Limits: 480|360
Beam Design 2021A12
1/3/2021 1
b = 5.125 in.
Beam Design 2021A12
1/3/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (152.50 + 5.5)] x (12 in./ft.)3 = 5.62 ft3
Volumespan = N[A x L] = 1 x [61.50 x 152.50] x (12 in./ft.)3 = 5.43 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.62 = 189.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.43 = 183.2 lbs
435 plf
270 plf
  ws = 14.42 plf
12.71 ft.
12.25 ft.
13.17 ft.
4736.05 lbs
4736.05 lbs
Beam Design 2021A12
1/3/2021 3
lu/d = = 2.00
Rb = = 4.75
 Rb = 4.75 < 50   ➜  OK
Beam Design 2021A12
1/3/2021 4
FbE = = 45157.32 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(1) = 2400.00 psi
CL =   = 0.997
CL = 0.997 < CV = 1.0
Fbx' = (2400)(1.00)(1)(1)(0.997) = 2393.3 psi
fb = = 1416.8 psi
 fb = 1416.8 psi < Fbx' = 2393.3 psi  (CSI = 0.59)   ➜  OK
fv* = = 93.95 psi
Beam Design 2021A12
1/3/2021 5
 fv* = 93.95 psi < Fvx' = 265.00 psi  (CSI = 0.35)   ➜  OK
fv = = 111.49 psi
 fv = 111.49 psi < Fvx' = 265.00 psi  (CSI = 0.42)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
ΔLL = = 0.19 in.
(L/d)LL = 152.50 / 0.19 = 794
 ΔLL = 0.19 in = L/794 < L/480   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 152.50 / 0.32 = 480
 ΔTL = 0.32 in = L/480 < L/360   ➜  OK
Beam Design 2021A12
1/3/2021 6
fc⊥ = = 168.0 psi
 fc⊥ = 168.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.26)   ➜  OK
Beam Design 2021A12
1/3/2021 7
