Design Span (L): 6.96 ft.
Clear Span: 6.50 ft.
Total Span: 7.42 ft.
Bearing (lb): 5.5 in.
Live Load: 3300 lbs
Dead Load: 50 lbs
Selfweight: 55.8 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 59.5 lbs
Load Duration: 1.25
Beam Design 2021A119
2/6/2021 1
2/6/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (83.50 + 5.5)] x (12 in./ft.)3 = 1.74 ft3
Volumespan = N[A x L] = 2 x [16.88 x 83.50] x (12 in./ft.)3 = 1.63 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.74 = 59.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.63 = 55.8 lbs
3300 lbs
50 lbs
ws = 8.02 plf
6.96 ft.
6.50 ft.
7.42 ft.
1704.73 lbs
1704.73 lbs
2/6/2021 3
Fbx' = (900)(1.25)(1)(1)(1)(1)(1)(1) = 1125.0 psi
fb = = 1114.2 psi
 fb = 1114.2 psi < Fbx' = 1125.0 psi  (CSI = 0.99)   ➜  OK
2/6/2021 4
fv* = = 75.35 psi
 fv* = 75.35 psi < Fvx' = 225.00 psi  (CSI = 0.33)   ➜  OK
fv = = 75.68 psi
 fv = 75.68 psi < Fvx' = 225.00 psi  (CSI = 0.34)   ➜  OK
2/6/2021 5
ΔLL =   =   = 0.07 in.
(L/d)LL = 83.50 / 0.07 = 1188
 ΔLL = 0.07 in = L/1188 < L/180   ➜  OK
ΔTL =   =   = 0.07 in.
(L/d)TL = 83.50 / 0.07 = 1158
 ΔTL = 0.07 in = L/1158 < L/120   ➜  OK
fc⊥ = = 103.3 psi
 fc⊥ = 103.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
2/6/2021 6
