Grade: 24F-V8 1.8E SP/SP
Size: 5.5 x 16.5
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Dead Load: 900 plf
Selfweight: 377.8 lbs
Dist. Selfweight: 23.25 plf
Total Weight: 383.6 lbs
CV Volume Factor 0.993b - - - - -
Beam Design 2021A117
2/6/2021 1
d = 16.500 in.
2/6/2021 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (195.00 + 3)] x (12 in./ft.)3 = 10.40 ft3
Volumespan = N[A x L] = 1 x [90.75 x 195.00] x (12 in./ft.)3 = 10.24 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 10.40 = 383.6 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 10.24 = 377.8 lbs
Distributed Self Weight (ws) = = 23.25 plf
900 plf
  ws = 23.25 plf
16.25 ft.
16.50 ft.
8441.80 lbs
8441.80 lbs
2/6/2021 3
CV = = 0.993
CV = 0.993 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.993) = 2741.8 psi
fb = = 1624.1 psi
 fb = 1624.1 psi < Fbx' = 2741.8 psi  (CSI = 0.59)   ➜  OK
2/6/2021 4
fv* = = 114.16 psi
 fv* = 114.16 psi < Fvx' = 345.00 psi  (CSI = 0.33)   ➜  OK
fv = = 137.42 psi
 fv = 137.42 psi < Fvx' = 345.00 psi  (CSI = 0.40)   ➜  OK
2/6/2021 5
ΔLL = = 0.04 in.
(L/d)LL = 195.00 / 0.04 = 4606
 ΔLL = 0.04 in = L/4606 < L/180   ➜  OK
ΔTL = = 0.43 in.
(L/d)TL = 195.00 / 0.43 = 450
 ΔTL = 0.43 in = L/450 < L/120   ➜  OK
fc⊥ = = 511.6 psi
 fc⊥ = 511.6 psi < Fc⊥x' = 740.00 psi  (CSI = 0.69)   ➜  OK
2/6/2021 6
