Beam Design - Floor Suppoirt
Species: Hem-Fir
Grade: HF No.2
Size: 2 x 4
Design Span (L): 3.42 ft.
Clear Span: 3.33 ft.
Total Span: 3.50 ft.
Bearing (lb): 1 in.
Dead Load: 20 plf
Selfweight: 3.9 lbs
Dist. Selfweight: 1.13 plf
Total Weight: 4.0 lbs
Incised Lumber: Yes
Notes: Flor Edge Beam
Beam Design Kiva Lints 31307 NE 144TH ST Archery Target
1/31/2021 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
G = 0.43
1/31/2021 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (41.00 + 1)] x (12 in./ft.)3 = 0.13 ft3
Volumespan = N[A x L] = 1 x [5.25 x 41.00] x (12 in./ft.)3 = 0.12 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 0.13 = 4.0 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 0.12 = 3.9 lbs
Distributed Self Weight (ws) = = 1.13 plf
20 plf
ws = 1.13 plf
3.42 ft.
3.33 ft.
3.50 ft.
212.00 lbs
212.00 lbs
1/31/2021 3
lu/d = = 6.86
Rb = = 8.77
 Rb = 8.77 < 50   ➜  OK
1/31/2021 4
Eminy' = Eminy(CM)(Ct)(Ci) = 470000(0.9)(1)(0.95) = 401850 psi
FbE = = 6270.20 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (850)(1.00)(0.85)(1)(1.5)(0.8)(1) = 867.00 psi
CL =   = 0.992
Fbx' = (850)(1.00)(0.85)(1)(0.992)(1.5)(0.8)(1) = 860.2 psi
fb = = 692.7 psi
 fb = 692.7 psi < Fbx' = 860.2 psi  (CSI = 0.81)   ➜  OK
Fvx' = (150)(1.00)(0.97)(1)(0.8) = 116.40 psi
fv* = = 49.03 psi
 fv* = 49.03 psi < Fvx' = 116.40 psi  (CSI = 0.42)   ➜  OK
fv = = 59.13 psi
 fv = 59.13 psi < Fvx' = 116.40 psi  (CSI = 0.51)   ➜  OK
1/31/2021 5
Ex' = Ex(CM)(Ct)(Ci) = 1300000(0.9)(1)(0.95) = 1111500 psi
ΔLL = = 0.05 in.
(L/d)LL = 41.00 / 0.05 = 796
 ΔLL = 0.05 in = L/796 < L/180   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 41.00 / 0.06 = 657
 ΔTL = 0.06 in = L/657 < L/120   ➜  OK
Ab = b x lb = 1.5 x 1 = 1.50 in2
fc⊥ = = 141.3 psi
 fc⊥ = 141.3 psi < Fc⊥x' = 271.35 psi  (CSI = 0.52)   ➜  OK
1/31/2021 6
