Grade: DF SS
Design Span (L): 15.25 ft.
Clear Span: 15.00 ft.
Total Span: 15.50 ft.
Live Load: 15 plf
Dead Load: 10 plf
Selfweight: 59.8 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 60.7 lbs
Beam Design 2021A110
1/30/2021 1
1/30/2021 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (183.00 + 3)] x (12 in./ft.)3 = 1.78 ft3
Volumespan = N[A x L] = 2 x [8.25 x 183.00] x (12 in./ft.)3 = 1.75 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.78 = 60.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.75 = 59.8 lbs
15 plf
10 plf
ws = 3.92 plf
15.25 ft.
15.00 ft.
15.50 ft.
224.12 lbs
224.12 lbs
1/30/2021 3
lu/d = = 4.36
Rb = = 5.50
 Rb = 5.50 < 50   ➜  OK
1/30/2021 4
FbE = = 27405.12 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1500)(1.15)(1)(1)(1.3)(1)(1) = 2242.50 psi
CL =   = 0.996
Fbx' = (1500)(1.15)(1)(1)(0.996)(1.3)(1)(1) = 2232.6 psi
fb = = 667.0 psi
 fb = 667.0 psi < Fbx' = 2232.6 psi  (CSI = 0.30)   ➜  OK
fv* = = 18.84 psi
 fv* = 18.84 psi < Fvx' = 207.00 psi  (CSI = 0.09)   ➜  OK
fv = = 20.05 psi
 fv = 20.05 psi < Fvx' = 207.00 psi  (CSI = 0.10)   ➜  OK
1/30/2021 5
ΔLL = = 0.23 in.
(L/d)LL = 183.00 / 0.23 = 792
 ΔLL = 0.23 in = L/792 < L/360   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 183.00 / 0.45 = 411
 ΔTL = 0.45 in = L/411 < L/240   ➜  OK
fc⊥ = = 24.9 psi
 fc⊥ = 24.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.04)   ➜  OK
1/30/2021 6
