Size: 5.125 x 24
Design Span (L): 16.71 ft.
Clear Span: 16.25 ft.
Total Span: 17.17 ft.
Bearing (lb): 5.5 in.
Live Load: 0 lbs
Dead Load: 13650 lbs
Selfweight: 481.8 lbs
Dist. Selfweight: 28.84 plf
Total Weight: 495.0 lbs
Defl. Limits: 480|360
CL Beam Stability Factor 0.925 - - - - -
CV Volume Factor 0.955b - - - - -
Beam Design 2021A11
1/3/2021 1
b = 5.125 in.
d = 24.000 in.
A = 5.125 x 24.000 = 123.00 in.2
Sx = (5.125)(24.000)2/6 = 492.00 in.3
Sy = (5.125)2(24.000)/6 = 105.06 in.3
Ix = (5.125)(24.000)3/12 = 5904.00 in.4
Iy = (5.125)3(24.000)/12 = 269.22 in.4
Beam Design 2021A11
1/3/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [123.00 x (200.50 + 5.5)] x (12 in./ft.)3 = 14.66 ft3
Volumespan = N[A x L] = 1 x [123.00 x 200.50] x (12 in./ft.)3 = 14.27 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 14.66 = 495.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 14.27 = 481.8 lbs
Distributed Self Weight (ws) = = 28.84 plf
0 lbs
13650 lbs
  ws = 28.84 plf
16.71 ft.
16.25 ft.
17.17 ft.
7072.52 lbs
7072.52 lbs
Beam Design 2021A11
1/3/2021 3
lu = Unbraced Length = 16.708 ft.
lu/d = = 8.35
le = 1.37lu + 3d = 1.37(200.5) + 3(24) = 346.68 in. = 28.89 ft.  (NDS Table 3.3.3)
Rb = = 17.80
 Rb = 17.80 < 50   ➜  OK
Beam Design 2021A11
1/3/2021 4
FbE = = 3219.95 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(0.9)(1)(1) = 2160.00 psi
CL =   = 0.925
CV = = 0.955
CL = 0.925 < CV = 0.955
Fbx' = (2400)(0.9)(1)(1)(0.925) = 1997.0 psi
fb = = 1415.2 psi
 fb = 1415.2 psi < Fbx' = 1997.0 psi  (CSI = 0.71)   ➜  OK
Fvx' = (265)(0.9)(1)(1) = 238.50 psi
fv* = = 85.47 psi
Beam Design 2021A11
1/3/2021 5
 fv* = 85.47 psi < Fvx' = 238.50 psi  (CSI = 0.36)   ➜  OK
fv = = 86.17 psi
 fv = 86.17 psi < Fvx' = 238.50 psi  (CSI = 0.36)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
ΔLL =   =   = 0.00 in.
(L/d)LL = 200.50 / 0.00 = ∞
 ΔLL = 0.00 in = L/∞ < L/480   ➜  OK
ΔTL =   =   = 0.22 in.
(L/d)TL = 200.50 / 0.22 = 910
 ΔTL = 0.22 in = L/910 < L/360   ➜  OK
Beam Design 2021A11
1/3/2021 6
fc⊥ = = 250.9 psi
 fc⊥ = 250.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.39)   ➜  OK
Beam Design 2021A11
1/3/2021 7
