Grade: SPF SS
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 500 lbs
Dead Load: 0 lbs
Selfweight: 97.2 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 98.9 lbs
Defl. Limits: 480|360
CL Beam Stability Factor 0.987 - - - - -
Beam Design 2021A105
1/29/2021 1
1/29/2021 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (177.00 + 3)] x (12 in./ft.)3 = 3.40 ft3
Volumespan = N[A x L] = 3 x [10.88 x 177.00] x (12 in./ft.)3 = 3.34 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.40 = 98.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.34 = 97.2 lbs
500 lbs
0 lbs
ws = 6.59 plf
14.75 ft.
14.50 ft.
15.00 ft.
299.44 lbs
299.44 lbs
1/29/2021 3
lu = Unbraced Length = 14.750 ft.
lu/d = = 24.41
le = 1.37lu + 3d = 1.37(177.0) + 3(7.25) = 264.24 in. = 22.02 ft.  (NDS Table 3.3.3)
Rb = = 9.73
 Rb = 9.73 < 50   ➜  OK
1/29/2021 4
FbE = = 6976.42 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1250)(1.00)(1)(1)(1.2)(1)(1) = 1500.00 psi
CL =   = 0.987
Fbx' = (1250)(1.00)(1)(1)(0.987)(1.2)(1)(1) = 1480.1 psi
fb = = 615.8 psi
 fb = 615.8 psi < Fbx' = 1480.1 psi  (CSI = 0.42)   ➜  OK
fv* = = 13.55 psi
 fv* = 13.55 psi < Fvx' = 135.00 psi  (CSI = 0.10)   ➜  OK
fv = = 13.73 psi
 fv = 13.73 psi < Fvx' = 135.00 psi  (CSI = 0.10)   ➜  OK
1/29/2021 5
LL Allowable: L/480
TL Allowable: L/360
ΔLL =   =   = 0.27 in.
(L/d)LL = 177.00 / 0.27 = 657
 ΔLL = 0.27 in = L/657 < L/480   ➜  OK
ΔTL =   =   = 0.30 in.
(L/d)TL = 177.00 / 0.30 = 586
 ΔTL = 0.30 in = L/586 < L/360   ➜  OK
fc⊥ = = 22.2 psi
 fc⊥ = 22.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.05)   ➜  OK
1/29/2021 6
