Beam Design - 1st Flr Joists
Grade: DF No.1
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 53.33 plf
Dead Load: 17.75 plf
Selfweight: 19.1 lbs
Dist. Selfweight: 1.96 plf
Total Weight: 19.6 lbs
Beam Design 1633 S Berlin Dr 2021A1
1/3/2021 1
1/3/2021 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (117.00 + 3)] x (12 in./ft.)3 = 0.57 ft3
Volumespan = N[A x L] = 1 x [8.25 x 117.00] x (12 in./ft.)3 = 0.56 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.57 = 19.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.56 = 19.1 lbs
53.33 plf
17.75 plf
ws = 1.96 plf
9.75 ft.
9.50 ft.
10.00 ft.
365.20 lbs
365.20 lbs
1/3/2021 3
Fbx' = (1000)(1.15)(1)(1)(1)(1.3)(1)(1) = 1495.0 psi
fb = = 1377.2 psi
 fb = 1377.2 psi < Fbx' = 1495.0 psi  (CSI = 0.92)   ➜  OK
1/3/2021 4
fv* = = 58.65 psi
 fv* = 58.65 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
fv = = 64.74 psi
 fv = 64.74 psi < Fvx' = 207.00 psi  (CSI = 0.31)   ➜  OK
1/3/2021 5
ΔLL = = 0.31 in.
(L/d)LL = 117.00 / 0.31 = 381
 ΔLL = 0.31 in = L/381 < L/180   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 117.00 / 0.42 = 279
 ΔTL = 0.42 in = L/279 < L/120   ➜  OK
fc⊥ = = 81.2 psi
 fc⊥ = 81.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.13)   ➜  OK
1/3/2021 6
