Size: 5.125 x 10.5
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 240 plf
Dead Load: 60 plf
Selfweight: 215.4 lbs
Dist. Selfweight: 13.25 plf
Total Weight: 218.7 lbs
Beam Design 2020A99
5/17/2020 1
b = 5.125 in.
d = 10.500 in.
A = 5.125 x 10.500 = 53.81 in.2
Sx = (5.125)(10.500)2/6 = 94.17 in.3
Sy = (5.125)2(10.500)/6 = 45.96 in.3
Ix = (5.125)(10.500)3/12 = 494.40 in.4
Iy = (5.125)3(10.500)/12 = 117.78 in.4
Beam Design 2020A99
5/17/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [53.81 x (195.00 + 3)] x (12 in./ft.)3 = 6.17 ft3
Volumespan = N[A x L] = 1 x [53.81 x 195.00] x (12 in./ft.)3 = 6.07 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 6.17 = 218.7 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 6.07 = 215.4 lbs
Distributed Self Weight (ws) = = 13.25 plf
240 plf
60 plf
  ws = 13.25 plf
16.25 ft.
16.50 ft.
2584.35 lbs
2584.35 lbs
Beam Design 2020A99
5/17/2020 3
Fbx' = (2400)(1.00)(0.8)(1)(1.0) = 1920.0 psi
fb = = 1317.6 psi
 fb = 1317.6 psi < Fbx' = 1920.0 psi  (CSI = 0.69)   ➜  OK
Beam Design 2020A99
5/17/2020 4
Fvx' = (265)(1.00)(0.875)(1) = 231.88 psi
fv* = = 63.31 psi
 fv* = 63.31 psi < Fvx' = 231.88 psi  (CSI = 0.27)   ➜  OK
fv = = 70.95 psi
 fv = 70.95 psi < Fvx' = 231.88 psi  (CSI = 0.31)   ➜  OK
Beam Design 2020A99
5/17/2020 5
ΔLL = = 0.51 in.
(L/d)LL = 195.00 / 0.51 = 384
 ΔLL = 0.51 in = L/384 < L/360   ➜  OK
ΔTL = = 0.66 in.
(L/d)TL = 195.00 / 0.66 = 294
 ΔTL = 0.66 in = L/294 < L/240   ➜  OK
fc⊥ = = 168.1 psi
 fc⊥ = 168.1 psi < Fc⊥x' = 344.50 psi  (CSI = 0.49)   ➜  OK
Beam Design 2020A99
5/17/2020 6
