Species: Hem-Fir
Grade: HF SS
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 240 plf
Dead Load: 60 plf
Selfweight: 38.6 lbs
Dist. Selfweight: 4.68 plf
Total Weight: 39.8 lbs
Beam Design 2020A98
5/17/2020 1
G = 0.43
Beam Design 2020A98
5/17/2020 2
= 30.99 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (99.00 + 3)] x (12 in./ft.)3 = 1.28 ft3
Volumespan = N[A x L] = 2 x [10.88 x 99.00] x (12 in./ft.)3 = 1.25 ft3
Total Weight (WT) = ρw x Volumetotal = 30.99 x 1.28 = 39.8 lbs
Self Weight (WS) = ρw x Volumespan = 30.99 x 1.25 = 38.6 lbs
Distributed Self Weight (ws) = = 4.68 plf
240 plf
60 plf
ws = 4.68 plf
8.25 ft.
8.50 ft.
1294.89 lbs
1294.89 lbs
Beam Design 2020A98
5/17/2020 3
Fbx' = (1400)(1.00)(0.85)(1)(1)(1.2)(1)(1) = 1428.0 psi
fb = = 1183.6 psi
 fb = 1183.6 psi < Fbx' = 1428.0 psi  (CSI = 0.83)   ➜  OK
Beam Design 2020A98
5/17/2020 4
Fvx' = (150)(1.00)(0.97)(1)(1) = 145.50 psi
fv* = = 73.98 psi
 fv* = 73.98 psi < Fvx' = 145.50 psi  (CSI = 0.51)   ➜  OK
fv = = 86.68 psi
 fv = 86.68 psi < Fvx' = 145.50 psi  (CSI = 0.60)   ➜  OK
Beam Design 2020A98
5/17/2020 5
ΔLL = = 0.18 in.
(L/d)LL = 99.00 / 0.18 = 543
 ΔLL = 0.18 in = L/543 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 99.00 / 0.23 = 428
 ΔTL = 0.23 in = L/428 < L/240   ➜  OK
fc⊥ = = 143.9 psi
 fc⊥ = 143.9 psi < Fc⊥x' = 271.35 psi  (CSI = 0.53)   ➜  OK
Beam Design 2020A98
5/17/2020 6
