Species: Hem-Fir
Grade: HF SS
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Live Load: 240 plf
Dead Load: 60 plf
Selfweight: 169.9 lbs
Dist. Selfweight: 10.46 plf
Total Weight: 172.5 lbs
Beam Design 2020A97
5/16/2020 1
G = 0.43
Beam Design 2020A97
5/16/2020 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 5.80 ft3
Volumespan = N[A x L] = 3 x [16.88 x 195.00] x (12 in./ft.)3 = 5.71 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 5.80 = 172.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 5.71 = 169.9 lbs
Distributed Self Weight (ws) = = 10.46 plf
240 plf
60 plf
ws = 10.46 plf
16.25 ft.
16.50 ft.
2561.27 lbs
2561.27 lbs
Beam Design 2020A97
5/16/2020 3
Fbx' = (1400)(1.00)(1)(1)(1)(1)(1)(1) = 1400.0 psi
fb = = 1295.5 psi
 fb = 1295.5 psi < Fbx' = 1400.0 psi  (CSI = 0.93)   ➜  OK
Beam Design 2020A97
5/16/2020 4
Fvx' = (150)(1.00)(1)(1)(1) = 150.00 psi
fv* = = 66.12 psi
 fv* = 66.12 psi < Fvx' = 150.00 psi  (CSI = 0.44)   ➜  OK
fv = = 74.74 psi
 fv = 74.74 psi < Fvx' = 150.00 psi  (CSI = 0.50)   ➜  OK
Beam Design 2020A97
5/16/2020 5
ΔLL = = 0.44 in.
(L/d)LL = 195.00 / 0.44 = 442
 ΔLL = 0.44 in = L/442 < L/360   ➜  OK
ΔTL = = 0.57 in.
(L/d)TL = 195.00 / 0.57 = 342
 ΔTL = 0.57 in = L/342 < L/240   ➜  OK
fc⊥ = = 189.7 psi
 fc⊥ = 189.7 psi < Fc⊥x' = 405.00 psi  (CSI = 0.47)   ➜  OK
Beam Design 2020A97
5/16/2020 6
