Design Span (L): 16.42 ft.
Clear Span: 16.08 ft.
Total Span: 16.75 ft.
Bearing (lb): 4 in.
Live Load: 250 plf
Selfweight: 148.5 lbs
Dist. Selfweight: 9.04 plf
Total Weight: 151.5 lbs
Beam Design 2020A95
5/14/2020 1
Beam Design 2020A95
5/14/2020 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (197.00 + 4)] x (12 in./ft.)3 = 3.93 ft3
Volumespan = N[A x L] = 2 x [16.88 x 197.00] x (12 in./ft.)3 = 3.85 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 3.93 = 151.5 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 3.85 = 148.5 lbs
Distributed Self Weight (ws) = = 9.04 plf
250 plf
ws = 9.04 plf
16.42 ft.
16.08 ft.
16.75 ft.
2797.66 lbs
2797.66 lbs
Beam Design 2020A95
5/14/2020 3
lu/d = = 2.13
Rb = = 7.86
 Rb = 7.86 < 50   ➜  OK
Beam Design 2020A95
5/14/2020 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(1) = 459000 psi
FbE = = 8912.62 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.15)(1)(1)(1)(1)(1) = 862.50 psi
CL =   = 0.995
Fbx' = (750)(1.15)(1)(1)(0.995)(1)(1)(1) = 857.9 psi
fb = = 2134.1 psi
 fb = 2134.1 psi > Fbx' = 857.9 psi  (CSI = 2.49)   ➜  NG
fv* = = 107.95 psi
 fv* = 107.95 psi < Fvx' = 195.21 psi  (CSI = 0.55)   ➜  OK
fv = = 121.87 psi
 fv = 121.87 psi < Fvx' = 195.21 psi  (CSI = 0.62)   ➜  OK
Beam Design 2020A95
5/14/2020 5
ΔLL = = 0.91 in.
(L/d)LL = 197.00 / 0.91 = 216
 ΔLL = 0.91 in = L/216 < L/180   ➜  OK
ΔTL = = 1.22 in.
(L/d)TL = 197.00 / 1.22 = 162
 ΔTL = 1.22 in = L/162 < L/120   ➜  OK
fc⊥ = = 233.1 psi
 fc⊥ = 233.1 psi < Fc⊥x' = 378.55 psi  (CSI = 0.62)   ➜  OK
Beam Design 2020A95
5/14/2020 6
