Grade: SPF No.2
Size: 2 x 4
Design Span (L): 5.81 ft.
Clear Span: 5.56 ft.
Total Span: 6.06 ft.
Live Load: 113.4 plf
Dead Load: 19.75 plf
Selfweight: 12.3 lbs
Dist. Selfweight: 2.12 plf
Total Weight: 12.9 lbs
Beam Design 2020A93
5/13/2020 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
Beam Design 2020A93
5/13/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [5.25 x (69.76 + 3)] x (12 in./ft.)3 = 0.44 ft3
Volumespan = N[A x L] = 2 x [5.25 x 69.76] x (12 in./ft.)3 = 0.42 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.44 = 12.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.42 = 12.3 lbs
Distributed Self Weight (ws) = = 2.12 plf
113.4 plf
19.75 plf
ws = 2.12 plf
5.81 ft.
5.56 ft.
6.06 ft.
410.08 lbs
410.08 lbs
Beam Design 2020A93
5/13/2020 3
lu = Unbraced Length = 5.813 ft.
lu/d = = 19.93
le = 1.63lu + 3d = 1.63(69.8) + 3(3.5) = 124.20 in. = 10.35 ft.  (NDS Table 3.3.3)
Rb = = 6.95
 Rb = 6.95 < 50   ➜  OK
Beam Design 2020A93
5/13/2020 4
FbE = = 12670.57 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.00)(1)(1)(1.5)(1)(1) = 1312.50 psi
CL =   = 0.994
Fbx' = (875)(1.00)(1)(1)(0.994)(1.5)(1)(1) = 1305.0 psi
fb = = 1119.4 psi
 fb = 1119.4 psi < Fbx' = 1305.0 psi  (CSI = 0.86)   ➜  OK
fv* = = 50.53 psi
 fv* = 50.53 psi < Fvx' = 135.00 psi  (CSI = 0.37)   ➜  OK
fv = = 56.17 psi
 fv = 56.17 psi < Fvx' = 135.00 psi  (CSI = 0.42)   ➜  OK
Beam Design 2020A93
5/13/2020 5
ΔLL = = 0.19 in.
(L/d)LL = 69.76 / 0.19 = 359
 ΔLL = 0.19 in = L/359 < L/240   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 69.76 / 0.23 = 301
 ΔTL = 0.23 in = L/301 < L/180   ➜  OK
fc⊥ = = 45.6 psi
 fc⊥ = 45.6 psi < Fc⊥x' = 425.00 psi  (CSI = 0.11)   ➜  OK
Beam Design 2020A93
5/13/2020 6
