Beam Design - Test
Grade: DF No.1 & Btr
Size: 4 x 10
Design Span (L): 14.33 ft.
Clear Span: 14.17 ft.
Total Span: 14.50 ft.
Bearing (lb): 2 in.
Live Load: 90 plf
Dead Load: 70 plf
Selfweight: 110.2 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 111.5 lbs
Beam Design Brian Yu Rty 2333
5/10/2020 1
5/10/2020 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (172.00 + 2)] x (12 in./ft.)3 = 3.26 ft3
Volumespan = N[A x L] = 1 x [32.38 x 172.00] x (12 in./ft.)3 = 3.22 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.26 = 111.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.22 = 110.2 lbs
90 plf
70 plf
ws = 7.69 plf
14.33 ft.
14.17 ft.
14.50 ft.
1215.72 lbs
1215.72 lbs
5/10/2020 3
Fbx' = (1200)(1.00)(1)(1)(1)(1.2)(1)(1) = 1440.0 psi
fb = = 1035.3 psi
 fb = 1035.3 psi < Fbx' = 1440.0 psi  (CSI = 0.72)   ➜  OK
5/10/2020 4
fv* = = 49.69 psi
 fv* = 49.69 psi < Fvx' = 180.00 psi  (CSI = 0.28)   ➜  OK
fv = = 55.68 psi
 fv = 55.68 psi < Fvx' = 180.00 psi  (CSI = 0.31)   ➜  OK
5/10/2020 5
ΔLL = = 0.21 in.
(L/d)LL = 172.00 / 0.21 = 836
 ΔLL = 0.21 in = L/836 < L/180   ➜  OK
ΔTL = = 0.38 in.
(L/d)TL = 172.00 / 0.38 = 449
 ΔTL = 0.38 in = L/449 < L/120   ➜  OK
Ab = b x lb = 3.5 x 2 = 7.00 in2
fc⊥ = = 173.7 psi
 fc⊥ = 173.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.28)   ➜  OK
5/10/2020 6
