Beam Design - Typical Short Beam
Grade: SPF No.2
Design Span (L): 7.79 ft.
Clear Span: 7.41 ft.
Total Span: 8.16 ft.
Bearing (lb): 4.5 in.
Live Load: 526 plf
Dead Load: 184 plf
Selfweight: 53.1 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 55.6 lbs
Beam Design Chuck Vreisema 1216 James, Wallaceburg 20200597
5/8/2020 1
5/8/2020 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (93.42 + 4.5)] x (12 in./ft.)3 = 1.91 ft3
Volumespan = N[A x L] = 2 x [16.88 x 93.42] x (12 in./ft.)3 = 1.82 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.91 = 55.6 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.82 = 53.1 lbs
526 plf
184 plf
ws = 6.82 plf
7.79 ft.
7.41 ft.
8.16 ft.
2924.62 lbs
2924.62 lbs
5/8/2020 3
fb = = 1029.8 psi
 fb = 1029.8 psi > Fbx' = 1006.2 psi  (CSI = 1.02)   ➜  NG
5/8/2020 4
fv* = = 94.14 psi
 fv* = 94.14 psi < Fvx' = 155.25 psi  (CSI = 0.61)   ➜  OK
fv = = 124.01 psi
 fv = 124.01 psi < Fvx' = 155.25 psi  (CSI = 0.80)   ➜  OK
5/8/2020 5
ΔLL = = 0.09 in.
(L/d)LL = 93.42 / 0.09 = 1071
 ΔLL = 0.09 in = L/1071 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 93.42 / 0.12 = 786
 ΔTL = 0.12 in = L/786 < L/240   ➜  OK
Ab = b x lb = 1.5 x 4.5 = 6.75 in2
fc⊥ = = 216.6 psi
 fc⊥ = 216.6 psi < Fc⊥x' = 425.00 psi  (CSI = 0.51)   ➜  OK
5/8/2020 6
